PDF.js Express Plus (@pdftron/pdfjs-express)
v8.7.0
I am building a prototype in which I am importing individual annotations on state update.
I am using mock data with exported xfdf strings set as a string-type property
The way I’m achieving this is by deleting annotations, then importing the next selected annotations.
Annotations with all enabled tools are importing as expected with the exception of annotations with FreeText.
I am not exactly sure what the failure is - just that the importAnnotations method is not successful in loading the annotations to the viewer.
I followed this topic, however, the suggested string.replace() did not resolve my issue.
Upgrading to 8.7.0 also did not resolve my issue.
WebViewer instance should import xfdf with FreeText annotations successfully
Issue is specific to annotations.
Exported xfdf:
<?xml version="1.0" encoding="UTF-8" ?><xfdf xmlns="http://ns.adobe.com/xfdf/" xml:space="preserve"><pdf-info xmlns="http://www.pdftron.com/pdfinfo" version="2" import-version="4" /><fields /><annots><freetext page="0" rect="486.170,775.870,848.130,822.990" flags="print" name="c631b34e-479a-5082-d592-73491cf8e540" title="Guest" subject="FreeText" date="D:20220819111822-04'00'" width="0" creationdate="D:20220819111817-04'00'" TextColor="#000000" FontSize="20"><trn-custom-data bytes="{"trn-wrapped-text-lines":"[\"Test Text Here \"]"}"/><contents>Test Text Here</contents><contents-richtext><body><p><span>Test Text Here</span></p></body></contents-richtext><defaultappearance>0 0 0 rg /Helvetica 20 Tf</defaultappearance><defaultstyle>font: Helvetica 20pt; text-align: left; text-vertical-align: top; color: #000000</defaultstyle></freetext></annots><pages><defmtx matrix="1,0,0,-1,0,1080" /></pages></xfdf>
Import snippet:
if (webViewerInstance) {
const annotations = await webViewerInstance.Core.annotationManager.getAnnotationsList();
await webViewerInstance.Core.annotationManager.deleteAnnotations(
annotations
if (submission.annotation) {
await webViewerInstance.Core.annotationManager.importAnnotations(submission.annotation);
UPDATE
After some poking around, I found that if I remove the <trn-custom-data /> tag entirely, the annotation loads as expected.
Not sure where that custom data is coming from. I am directly pushing annotation-header-tools into the header.
UPDATE
It appears that the issue has something to do with the way the value for trn-wrapped-text-lines is being encoded.
I was able to import the annotation xfdf after removing " from inside the parentheses
Before (not importing):
<trn-custom-data bytes="{"trn-auto-size-type":"auto","trn-wrapped-text-lines":"["Test Test]"}"/
After (importing):
<trn-custom-data bytes="{"trn-auto-size-type":"auto","trn-wrapped-text-lines":"[Test Test]"}"/>
Parsed XML:
