dustin
February 11, 2022, 3:30am
1
I cannot figure out how to add the full screen button to the main menu. Our users cannot find it behind the “gear” icon and it’s a core thing they need to access.
Code I tried below.
Full screen button to show on toolbar.
All
Any
instance.UI.setHeaderItems(header => {
const items = header.getItems();
items.splice(1, 0,
type: 'fullScreenButton',
toolName: 'fullScreenButton'
header.update(items);
system
3
Guides:
APIs:
Forums:
February 16, 2022, 3:37pm
4
Moving buttons to the header is a bit tricky right now, sorry about that. We’re working on improving these APIs.
The trick is to just create a new button like so
// disable the original one
instance.UI.disableElements(['fullscreenButton'])
instance.UI.setHeaderItems((header) => {
header.getHeader('default').push({
img: "icon-header-full-screen",
index: -1,
type: "actionButton",
element: 'fullScreenButton',
onClick: () => {
instance.UI.toggleFullScreen()
julio
February 16, 2022, 5:04pm
5
Do you have an example where I can change the icon when the window has fullscreen
dustin
February 16, 2022, 8:39pm
6
Thank you so much, Logan. That worked perfectly. Our users will be so happy!
February 18, 2022, 3:28pm
7
Hey Julio,
You can use a StatefulButton as documented on this page .
