Disable UI buttons in fullscreen mode
I would like to disable a set of buttons in the viewer by default, and enable them when the user goes full screen. Is there a way to do that out of the box ? Is there an event I can listen to to detect a switch to full screen ?
Buttons not displayed in default viewer, visible in full screen viewer.
Hey!
You can actually just use native DOM events for that:
  document.addEventListener('fullscreenchange', (event) => {
    if (document.fullscreenElement) {
      console.log(`Element: ${document.fullscreenElement.id} entered full-screen mode.`);
      console.log('Leaving full-screen mode.');
