I have a signature field I added to a PDF through Adobe Acrobat Pro. The PDF Express WebViewer does not recognize this as a signature field with the “SignHere” tag. Is this not supported in PDFJS?
WebViewer should display SignHere tag on signature field and allows for digital signature to be added.
Every document
JavaScript PDF Viewer Customize Forms DemoCustomize Form Style Demo for PDF Viewer
<script>
path: '../../lib', // path to the PDF.js Express'lib' folder on your server
licenseKey: 'Insert free license key here',
initialDoc: 'Affirmation Form Fields.pdf',
config: 'config.js'
// initialDoc: '/path/to/my/file.pdf', // You can also use documents on your server
.then(instance => {
// disable annotations
//instance.UI.disableFeatures([instance.UI.Feature.Annotations]);
Core.documentViewer.addEventListener('pageNumberUpdated', (pageNumber) => {
</script>
