| UI version | 8.1.0 |
| Core version | 8.1.1 |
| Build | MTAvMjEvMjAyMXw2OGY2MTQ1NWU= |
| WebViewer Server | false |
| Full API | false |
Is there a way to add a @mention functionality to the commenting system? If there isn’t, is there at least a way to separate the comments from other annotations and read the text content of the comment? This is so that with a bit of extra code, a sort of mentioning feature can be added to the PDF viewer.
It would highlight the name after the ‘@’ symbol like how one would see a notable difference in a chat application. (Note: This is only if a mentioning system can be implemented into the PDF Viewer.)
N/A
N/A
N/A
