I want to start with the advanced customization of the WebViewer. I need custom categories to mark the status of annotations.
I’ve followed the documentation:
I’m using a MacStudio with MacOS 14.3
node.js version: v20.11.0
npm version: 10.4.0
I got a lot of errors:
npm install
npm ERR! code ERESOLVE
npm ERR! ERESOLVE could not resolve
npm ERR!
npm ERR! While resolving: @babel/eslint-parser@7.21.8
npm ERR! Found: eslint@6.8.0
npm ERR! node_modules/eslint
npm ERR! dev eslint@“^6.8.0” from the root project
npm ERR! peer eslint@“>=4.0.0” from eslint-plugin-babel@5.3.1
npm ERR! node_modules/eslint-plugin-babel
npm ERR! dev eslint-plugin-babel@“^5.3.0” from the root project
npm ERR! 6 more (eslint-plugin-cypress, eslint-plugin-import, …)
npm ERR!
npm ERR! Could not resolve dependency:
npm ERR! peer eslint@“^7.5.0 || ^8.0.0” from @babel/eslint-parser@7.21.8
npm ERR! node_modules/@babel/eslint-parser
npm ERR! dev @babel/eslint-parser@“^7.16.0” from the root project
npm ERR!
npm ERR! Conflicting peer dependency: eslint@8.56.0
npm ERR!
npm ERR! Fix the upstream dependency conflict, or retry
npm ERR! this command with --force or --legacy-peer-deps
npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
Next try:
npm start --legacy-peer-deps
result:
npm WARN deprecated domexception@4.0.0: Use your platform’s native DOMException instead
npm WARN deprecated abab@2.0.6: Use your platform’s native atob() and btoa() methods instead
npm WARN deprecated urix@0.1.0: Please see GitHub - lydell/urix: [DEPRECATED] Makes Windows-style paths more unix and URI friendly.
npm WARN deprecated trim@0.0.1: Use String.prototype.trim() instead
npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: Array.prototype.sort() - JavaScript | MDN
npm WARN deprecated source-map-url@0.4.1: See GitHub - lydell/source-map-url: [DEPRECATED] Tools for working with sourceMappingURL comments.
npm WARN deprecated source-map-resolve@0.5.3: See GitHub - lydell/source-map-resolve: [DEPRECATED] Resolve the source map and/or sources for a generated file.
npm WARN deprecated sane@4.1.0: some dependency vulnerabilities fixed, support for node < 10 dropped, and newer ECMAScript syntax/features added
npm WARN deprecated resolve-url@0.2.1: GitHub - lydell/resolve-url: [DEPRECATED] Like Node.js’ `path.resolve`/`url.resolve` for the browser.
npm WARN deprecated redux-devtools-extension@2.13.9: Package moved to @redux-devtools/extension.
npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated flatten@1.0.3: flatten is deprecated in favor of utility frameworks such as lodash.
npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See There’s Math.random(), and then there’s Math.random() · V8 for details.
npm WARN deprecated fsevents@1.2.13: The v1 package contains DANGEROUS / INSECURE binaries. Upgrade to safe fsevents v2
npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
added 2692 packages, and audited 2693 packages in 3m
273 packages are looking for funding
run npm fund for details
131 vulnerabilities (2 low, 89 moderate, 35 high, 5 critical)
npm start
webviewer-ui@10.6.0 start
npx babel-node ./dev-server.js
Listening at localhost:3000 (http://192.168.1.222:3000)
node:internal/crypto/hash:68
this[kHandle] = new _Hash(algorithm, xofLen);
Error: error:0308010C:digital envelope routines::unsupported
at new Hash (node:internal/crypto/hash:68:19)
at Object.createHash (node:crypto:138:10)
at module.exports (…/webviewer-ui/node_modules/webpack/lib/util/createHash.js:135:53)
at NormalModule._initBuildHash (…/webviewer-ui/node_modules/webpack/lib/NormalModule.js:417:16)
at handleParseError (…/webviewer-ui/node_modules/webpack/lib/NormalModule.js:471:10)
at …/webviewer-ui/node_modules/webpack/lib/NormalModule.js:503:5
at …/webviewer-ui/node_modules/webpack/lib/NormalModule.js:358:12
at …/webviewer-ui/node_modules/loader-runner/lib/LoaderRunner.js:373:3
at iterateNormalLoaders (…/webviewer-ui/node_modules/loader-runner/lib/LoaderRunner.js:214:10)
at Array. (…/webviewer-ui/node_modules/loader-runner/lib/LoaderRunner.js:205:4)
at Storage.finished (…webviewer-ui/node_modules/enhanced-resolve/lib/CachedInputFileSystem.js:55:16)
at …/webviewer-ui/node_modules/enhanced-resolve/lib/CachedInputFileSystem.js:91:9
at …/webviewer-ui/node_modules/graceful-fs/graceful-fs.js:123:16
at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read/context:68:3) {
opensslErrorStack: [ ‘error:03000086:digital envelope routines::initialization error’ ],
library: ‘digital envelope routines’,
reason: ‘unsupported’,
code: ‘ERR_OSSL_EVP_UNSUPPORTED’
Node.js v20.11.0
Complete flawless install and build of provided source code
yes
I’m not able to load any document yet
