{PDF.js Express Plus}
{8.7.1}
{After loading a document, the letters are not displayed correctly and are partially covered with white. If I zoom in and then out again, the document is displayed correctly in the viewer again.}
{The document should load without problems so that each letter is readable}
{This issue happens in multiple documents}
{https://file-examples.com/storage/fe22116a7163ff1a2a32938/2017/10/file-sample_150kB.pdf}
{ if (instance === undefined) {
const newInstance = await WebViewer({
path: ‘/pdfjsexpress’, // path to the PDFTron ‘lib’ folder on your server
initialDoc: ‘’
}, viewerDiv.current as HTMLDivElement);
newInstance.setLanguage(‘de’)
setInstance(newInstance);
if (IsThemeDark()) {
instance.UI.setTheme(‘dark’);
else {
instance.UI.setTheme(‘light’);
const { documentViewer, annotationManager } = instance.Core;
setInstance(instance);
setDocViewer(documentViewer);
setAnnotManager(annotationManager);
