Annotation filtering doesn't reset on closing/opening section
Steps to reproduce:
  1. Annotate 2+ different texts (2 comments created)
  2. Type 1 text in “Search comments” (1 comment left)
  3. Click “Comments” icon at the top right at the toolbar. (Comments section is closed)
  4. Click “Comments” icon at the top right at the toolbar. (Comments section is open with 1 comment and empty input for “Search comments”)
It could be fixed by typing in something new and then deleted.
I assume it’s simple fix with reset of value on closing of section or you could set the value on the input back, the 2nd option will require investigation.
I could provide more screenshots or clip if you will share permissions
Hello Aliaksei,
We were able to reproduce this issue. I have submitted a report about this.
Darian
Hey, @darian.chen, thank you for submiting a report, could you please share any estimation related to fix reaching the library?
