I am adding labels to the annotations (these can be manual as well as programmatic). Normally, the behavior is as expected, but when the length of the label is a little longer, the letters/numbers overlap each other. You may see it in the attached link to the screenshot.As you can see, last digit of the label is being overlapped.
I want the width of the labels to be adjusted dynamically no matter what the size(width) of the annotation is.
Every Document
const freeTextAnnotation: any = addFreeTextAnnotation(Annotations, annotateData, rotatedX1, rotatedY1, rotation, customData, width);
freeTextAnnotation.setAutoSizeType(pdfInstance.Core.Annotations.FreeTextAnnotation.AutoSizeTypes.AUTO)
annotationManager.addAnnotation(freeTextAnnotation);
annotationManager.drawAnnotationsFromList([lastAnnotation, freeTextAnnotation]);
annotationManager.groupAnnotations(lastAnnotation, [freeTextAnnotation]);
const addFreeTextAnnotation = (Annotations: any, annotationData: any, x: any, y: any, rotation: any, customData: any, width: any = null) => {
if (!annotationData.page) return;
const freeText = new Annotations.FreeTextAnnotation();
freeText.PageNumber = Number(annotationData.page);
freeText.CustomData = customData
freeText.NoMove = true;
freeText.NoResize = true;
// const textWidth = annotationData.doorId.length * ((16) / 3);
switch (rotation) {
case 0:
freeText.X = x;
freeText.Y = y - 10 + freeText.Y
// freeText.Width = textWidth;//35;
freeText.Height = 10;
break;
case 90:
freeText.X = x - 10 + freeText.X;
freeText.Y = y - 10 + freeText.Y;
// freeText.Width = 10;
freeText.Height = 10;//35;
break;
case 270:
freeText.X = x + width;
freeText.Y = y;
break;
default:
// Handle other rotation angles if necessary
