Annotations not generating an element property on documents loaded after the first
PDF.js Express
Annotations generate properly on first render, but do not generate when a new document is loaded. Annotation values are generated with empty ‘element’ property, thus making them not appear on the PDF. A use hook is used to generated an array of stamps.
It is expected that annotations will appear on document
Issue happens on any document that isn’t the first document loaded.
Document agnostic
const [viewInstance, setViewInstance] = useState();
const { Annotations } = viewInstance ?? {};
const { isLoading, data } = useGetDocument(props.document.DocumentId);
const { annotationStamps } = useAnnotations(viewInstance, props.document);
const viewer = useRef(null);
useEffect(() => {
            licenseKey: process.env.REACT_APP_PDFJS_LICENSE,
            path: '/webviewer/lib',
        viewer.current,
    ).then((instance: typeof WebViewer) => {
        instance.UI.disableElements(['annotationCommentButton']);
        instance.UI.disableTools();
        instance.UI.disableElements(['pageNavOverlay']);
        instance.UI.disableElements(['eraserToolButton']);
        instance.UI.disableElements(['ribbons']);
        const { docViewer, Annotations } = instance;
        setViewInstance(instance);
        docViewer.addEventListener('documentLoaded', () => {
            // here you can get the document and perform actions on it,
            // such as removing pages
    // eslint-disable-next-line react-hooks/exhaustive-deps
useEffect(() => {
    if (isLoading || !data || !viewInstance) return;
    viewInstance.loadDocument(data, { filename: props.document.DocumentName });
    if (annotationStamps) {
        if (annotationStamps.length > 0) {
            annotationStamps.forEach((stamp: Core.Annotations.Annotation) => {
                console.log('Stamp', stamp);
                let annotationManager = viewInstance.Core.documentViewer.getAnnotationManager();
                annotationManager.addAnnotation(stamp);
}, [data, viewInstance]);
It appears the createInnerElement is not being called subsequent times after a new document load.
Solved by using a loaded state that is updated on the document loading event. Then placing the annotation generation in useEffect with the loaded dependecy. Check if loaded is true, then run annotations. If data is changed, set loaded to false.
