PDF.js Express Plus and pdfTron (trial for now)
PDFTron Version
8.12.0
I have a ppt file that was converted using cloudconvert as a tool to convert office-based files to pdf files so that I can preview in the web, problem is that on the provided file down below, the pages is showing missing parts when using PDFjs express + while it renders completely fine when using the PDFTron viewer.
Is there anyway, or any parameter I can use to properly view the file ?
This screenshot shows the issue
This screenshot shows the expected result
For now, I only found this issue on this document
WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free [original pptx file]
WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free [converted pdf file]
I used the examples provided in the public repos on github and simply changed the path to the file.
Thank u for your time ![]()
