Freetext Annotation Text padding
How do I put Freetext Annotation text padding?
There is an issue where the top of the text is cut off.
I want the text to be padded at the top so that the text is not cut off.
newAnnot.Width = 100;
newAnnot.Height = 30;
newAnnot.X = 10;
newAnnot.Y = 10;
newAnnot.FontSize = ‘20pt’;
newAnnot.TextColor = new Annotations.Color(0, 0, 0);
newAnnot.setPadding(new Annotations.Rect(0, 0, 0, 0));
newAnnot.StrokeThickness = 0;
newAnnot.setContents(‘Textrtrtr테스트중입니다.’);
annotManager.addAnnotation(newAnnot, true);
annotManager.redrawAnnotation(newAnnot);
You can change the values in ‘setPadding’ to add padding to the top.
newAnnot.setPadding(new Annotations.Rect(0, 0, 0, 50));
You’ll have to increase the height of the annotation as well.
We have some small improvements coming to the freetext annotation in the next patch so this may help with the text getting cut off as well.
