Hide comments and annotations checkboxes
Latest
Is there a way to hide the “Print comments” and “Print annotations” checkboxes from the print modal?
I have disabled the annotations using disableFeatures, but the checkbox is still there.
let disabledFeatures = [
    instance.UI.Feature.Download,
    instance.UI.Feature.Annotations,
instance.UI.disableFeatures(disabledFeatures);
They dont seem to have a data-element tag either
They should be hidden
You can remove them via CSS:
See this forum post for more details:
best regards,
Thanks.
I was thinking about using css, but they all have the same classes, so I dont see a way of targeting them without using a lot of not()
I did this and it seems to work. Feels a bit brittle though :slight_smile:
const iframeDoc = instance.UI.iframeWindow.document;
iframeDoc.querySelector('.settings-form .ui__choice:not(.ui__choice--radio)').remove();
