arman
June 8, 2022, 3:34am
1
When I create TextHiglightAnnotation by programmatically then it make difference from the default pdfjs TextHiglightAnnotation.
I want to create the TextHiglightAnnotation same as pdfjs default TextHiglightAnnotation
Yes. Need for all document annotation.
documentViewer.addEventListener('documentLoaded', () => {
const highlight = new Annotations.TextHighlightAnnotation();
highlight.Author = annot.Author;
highlight.Hidden = false;
highlight.Quads = annot.Quads;
highlight.StrokeColor = new Annotations.Color(255, 176, 176, 1);
highlight.PageNumber = annot.getPageNumber();
highlight.Locked = false;
highlight.setCustomData("trn-custom-data", "Test Data");
highlight.Subject = 'Highlight';
annotManager.addAnnotation(highlight, true);
annotManager.drawAnnotations(1);
Guides:
APIs:
Forums:
Hello arman,
Setting the contents of the highlight with: highlight.setContents('Test') will show “Test” in the comments panel like the default TextHighlight.
You can also use getSelectedText and getSelectedTextQuads to set the contents and get the Quads of the annotation PDFJS Express WebViewer Class: DocumentViewer
PDFTron
arman
June 9, 2022, 3:06am
5
Hey tgordon,
I set the contents using highlight.setContents(getSelectedText()). But you can see that the opacity of default pdfjs highlight annotation is less than the programatically created highlight annotation.
And when I click the edit button of default pdfjs highlight annotation, it show me a comment field and I can not edit the actual content but in self created annotation it give me the access to edit my actual content. Again when I drag the text of default pdfjs highlight annotation from PDF it edit the actual content in the right side bar. But when I drag the text of self created highlight annotation from pdf it do not edit my actual content, it create another text over my content.
See Video Ref Here
Here is my code snippet.
highlight.setContents(getSelectedText());
Hello arman,
It looks like you’ve created a whole new tool, I would suggest extending off the current TextHighlightCreateTool and adjusting the tool’s behaviour:
See more here: Customize PDF.js Express Viewer Annotations in Toolbar | Documentation
If you can send the tool’s code as well, this would help debug why the text isnt being shown in the notes panel when selecting text. Thanks!
PDFTron
arman
June 13, 2022, 5:57am
7
Here is my code. Please let me know what is the problem.
docViewer.on('textSelected', (quads, text, pageNumber) => {
if (text && quads && pageNumber) {
this.setState({ selectedTexts: text, selectedTextQuads: quads, selectedTextPageNumber: pageNumber });
instance.UI.textPopup.add({
type: 'actionButton',
title: '' ",
onClick: () => {
const { selectedTexts, selectedTextQuads, selectedTextPageNumber } = this.state;
if (selectedTexts && selectedTextQuads && selectedTextPageNumber) {
let r = 255;
let g = 176;
let b = 176;
highlight.Author = this.state.author;
highlight.Quads = this.state.selectedTextQuads;
highlight.StrokeColor = new Annotations.Color(r, g, b);
highlight.PageNumber = this.state.selectedTextPageNumber;
highlight.Locked = false; // is editable or not
highlight.setContents(this.state.selectedTexts);
highlight.Subject = 'Citation';
annotManager.addAnnotation(highlight);
BasicToaster.show({
message: 'Please select some text .',
intent: Intent.WARNING,
timeout: 6000
Hello arman,
Looking at your code, you are mixing our two different version’s name-spacing. Here is an updated code snippet using our v8.0+ name-spacing:
instance.Core.documentViewer.addEventListener('textSelected', (quads, text, pageNumber) => {
title: "",
onClick: () => {
let r = 255;
let g = 176;
let b = 176;
const highlight = new instance.Core.Annotations.TextHighlightAnnotation();
highlight.StrokeColor = new instance.Core.Annotations.Color(r, g, b);
instance.Core.annotationManager.addAnnotation(highlight);
BasicToaster.show({
timeout: 6000
Using this made the annotation correctly for me.
PDFTron
