We are highlighting Text with TextHighlight tool on documents that where scanned and got a full ocr on them. The TextHighlight tool does not highlight the correct text height. Seems to just highlight half of the needed height.
Thats a problem for us, because we are exporting xfdf after annotation has been done and need correct coordinates in the xfdf. Even the coordinates in xfdf just show us half of the needed text height.
Adobe Reader does highlight the correct text height, though.
Highlight full text height like Adobe Reader TextHighlight tool does.
It happens on all scanned documents with ocr in it.
Also I was unable to download the file with the link, can you provide another link to the file?
