How to raise AnnotationsLoaded Event?
Dear Support,
I’m trying to raise the annotationsLoaded event from my code.
Here is my piece of code : Unfortunatelly the annotationsLoaded event is not fired.
Anything I’m doing wrong ?
The code you have should work.
The following works for me:
  instance.Core.annotationManager.addEventListener('annotationsLoaded', () => {
    console.log('test')
  setTimeout(() => {
    instance.Core.annotationManager.trigger('annotationsLoaded')
  }, 1500)
Can you please make sure your trigger call is actually getting executed and that you are binding to the event properly.
