hiraki
1
| UI version |
8.7.0 |
| Core version |
8.7.4 |
| webviewer.min.js |
8.7.4 |
I questioned how to fix version mismatch in another topic.
I want to remove text-vertical-alignment div of freetext style popup. Is this possible?
We want to remove the bluely marked options.
n/a
n/a
n/a
Hello Hiraki,
You can hide the text-vertical-alignment by changing the CSS properties.
Here is a guide on how to customize styles in the viewer: PDF.js Express Viewer Style Customization (Color & CSS) | Documentation
licenseKey: 'YOUR_LICENSE_KEY',
path: 'lib',
css: 'path/to/stylesheet.css'
In the CSS file, you can add the following to hide the div.
.row.text-vertical-alignment {
display: none !important;
Darian
hiraki
4
Hi darian,
This perfectly worked!
Thank you for your help.
Kind regards,
hiraki
