Vertical text selection not working.
Vertical text selection should work, tried with PDF.js and PDFTron Viewer with the same documents and it does work properly.
Tried multiple documents, same behaviour.
Can’t provide the document.
Tried on demo page.
system
May 25, 2022, 8:05am
#3
Guides:
APIs:
Forums:
Hello v.condratiev,
Can you share screenshots of the current behaviour, and the expected behaviour?
We have a different text selection mode called “Rectangular” you can set it like so:
https://www.pdftron.com/api/web/Core.Tools.TextTool.html#selection_mode
PDFTron
Hello Tyler,
Yes, of course.
So this is the actual text that I’m trying to select.
I can’t select that vertical / sideways text.
I noticed that this happens for all vertical/sideways text and it does not matter what document I use.
If I try to open the file with PDF.js or PDFTron, this works properly.
Vadim
Hello v.condratiev,
Using test files on my end, which have sideways text, I am able to select them. I have a feeling this could be a file specific issue. I see you noted you cant provide the document, I could give you my email for which you can send the file if you would like.
PDFTron
Hi Tyler,
That would be great! I can send you the file.
Thank you!
Vadim
Hello v.condratiev,
Here is my email: tgordon@pdftron.com
PDFTron
Hi Tyler,
I sent you the file. Can you please confirm that you received it ?
Vadim
