PDF Express Js Plus
8.X.X.X
i need to increase the width/space of the action button label for example, ```
type: ‘actionButton’,
label: ‘1’,
onClick: () => console.log(‘clicked’),
but currently it is breaking into 3 lines
**Expected behaviour**
need to increase the width/space of the action button label for example, and arrange the action buttons one below the other```
type: 'actionButton',
label: '1',
onClick: () => console.log('clicked'),
```here in above code label = '1' instead of '1' i need to give 'Some text' with out line break,
**Does your issue happen with every document, or just one?**
Yes
**Link to document**
**Code snippet**
instance.UI.contextMenuPopup.update([
label: 'Test1',
label: 'Test2',
label: 'Test3',
