Invoice/watermark
!!! Issues that do not follow this template will be closed and removed !!!
Please fill out the following template as best you can. .
I received the invoce, #F94D9739-0039, and paid by Visa credit card automatically. However the watermark is show on the viewer. Would you check please ?
FYI, receipt number is 2244-0763.
Watermark visible on all documents
every document
NS
NS
Hello david.l1,
This should be resolved now. Let me know if it works for you.
