isSignedInitially is not a function
I am not get use this code in react for getting digital signature info. PDF.js Express Signature Field | Documentation
Ravi
Hi Ravi,
Could you please provide more context for this issue? Including a code snippet of the function call would be very helpful.
What version of PDFjs Express are you seeing this error on?
Zach Serviss
Hi Zach,
I am trying to know if the pdf file is already digitally signed.
WebViewer(...)
  .then(instance => {
    const { documentViewer, annotationManager } = instance.Core;
    documentViewer.addEventListener('annotationsLoaded', () => {
      const signatureWidgetAnnots = annotationManager.getAnnotationsList().filter(
        annot => annot instanceof Annotations.SignatureWidgetAnnotation
    signatureWidgetAnnots.forEach((annot) => {
      annot.isSignedInitially().then((isSigned) => {
        if (isSigned) {
          // if this signature field is signed initially
          // if this signature field is not signed initially
This is the code snippet
PDFjs version : “@pdftron/pdfjs-express”: “^8.4.0”
Ravi
Hi Ravi,
The function isSignedInitially should be isSignedDigitally since you are using 8.4. Migrating to PDF.js Express 8.0 | Documentation
It seems like that documentation is out of date. We are constantly looking for feedback and errors in our documentation so thank you for bringing this to our attention.
I just tested it myself and isSignedDigitally works.
Zach Serviss
Hi Zach
I am trying to use isSignedDigitally function to know the if the pdf file is already signed or not but it is not recognizing the digital signature on pdf file. I have opened the same file in Adobe Acrobat Reader , there it is showing the valid digital signature on the file.
I am attaching the digitally signed file.
NBA Return Slip_esigner (33).pdf (150.8 KB)
Can you please in this.
Ravi Basil
Hi Ravi,
So PDFjs Express doesn’t handle flattened annotations.
What I can recommend is to use the REST APIs to extract the signature annotations.
https://pdfjs.express/api/utils/ExpressUtils.html#extract
Here is some documentation on pricing and how to get started.
Zach Serviss
