Localhost domain (with subdomain and port) not reconised
License key doesn’t work with http://sub.domain.localhost:3000.
Error message on console:
PDFJSDocumentType.js:125 Error: PDFJS.express: A valid license key is required to use the view only build of PDF.js Express. Get your free license key at https://pdfjs.express/profile (account required)
License key should work for every “localhost” domain and subdomains
Every document.
import WebViewer from "@pdftron/pdfjs-express-viewer"
  path: '/pdfjsexpress/',
  licenseKey: 'tAuGf68iUvaw4V9b3MMv',
  initialDoc: 'https://pdftron.s3.amazonaws.com/downloads/pl/webviewer-demo.pdf',
}, document.getElementById("pdf-viewer"));
Can you confirm you have the correct package installed? PDF.js express and PDF.js express Viewer are separate products with different license keys. Please make sure you are using the right product for your license key.
If you still have issues, please try without the port as explained by this forum post:
