The active licence key is not working
“8.1.1”
I have active key licence for PDF.js Express Viewer but I my console it still says the error message:
A license key is required to use the view only build of PDF.js Express. Get your free license key at PDF.js Express (account required)
I think the fact that the document is not loading is because my licence key is not recognised as being valid.
It does on every document.
import React, { useRef, useEffect } from "react";
import WebViewer from "@pdftron/pdfjs-express-viewer";
const OpenPDF = () => {
  const viewer = useRef(null);
  useEffect(() => {
        path: '/webviewer/lib',
        initialDoc: 'https://bgrmihailsturdza.files.wordpress.com/2014/02/rebreanu-liviu-ion-i-cartea.pdf',
        licenseKey: '//'
      viewer.current,
    ).then((instance) => {
        const { Core } = instance;
        Core.documentViewer.addEventListener('pageNumberUpdated', (pageNumber) => {
  return (
    <div className="App">
      <div className="header">React sample</div>
      <div className="webviewer" ref={viewer}></div>
    </div>
export default OpenPDF;
Thank you!
Can you confirm that the key is being used on the same domain that it is registered to?
I use it on localhost and my domain is set to “http://localhost:3000/”
Should I put something else to use it in development mode?
I have the same problem. My Free PDF.js Express Viewer keys is registred to localhost, but not run.
I have a localhost server running but i’m actually using it in NWJS and not the localhost and its not working either, i’m getting the same errors as the guys above. Will localhost always be needed to run the free version?
Hey @user25
I do not understand what you mean by “I have a localhost server running but i’m actually using it in NWJS and not the localhost and its not working either”.
The license key domain should point to the domain of your production application - you do not need to set it to localhost. Valid license keys will always work on localhost for development purposes, regardless of the domain set.
