Using PDF.JS express on local domain
{For some reason the requested licence doesn’t seem to work on the document.dv.local webiste. It says “Error: PDFJS.express: A valid license key is required to use the view only build of PDF.js Express” The given licence is registered to dv.local (because it had problem with subdomains). The website can load resources from the outside(loads js files and css files from the internet) so i don’t see what the problem can be.}
{show the document in the iewer}
{every}
{the link is on the local network, can only be accessed with vpn}
{don’t have one}
Thank you for reaching pdfjs express forums,
Are you using the Viewer or the Plus version? Do you have the correct package installed for the respective license?
Do you have any failing network requests you can share the screenshot of?
