Opening bookmarks causes viewer to crash
We are currently running version 7.3.2 and have discovered that opening the bookmarks tab crashes the viewer. I have bumped us up to the latest (7.3.4) and the issue is still there. I have also tried on the demo site and it seemed to work normally there, but I noticed that the demo site appears to be running v7.3.0. I then tried running 7.3.0 locally and it worked properly. So I suspect the bug was introduced some time after 7.3.0.
This is the example of the errors showing in the console:
Uncaught TypeError: n.getIndex is not a function
at Object.getPath (webviewer-ui.min.js:50)
at Object.getOutlineId (webviewer-ui.min.js:50)
at webviewer-ui.min.js:50
at Array.map (<anonymous>)
at $i (webviewer-ui.min.js:34)
at Ra (webviewer-ui.min.js:34)
at ml (webviewer-ui.min.js:34)
at us (webviewer-ui.min.js:34)
at ls (webviewer-ui.min.js:34)
Here is a demonstration of the issue:
bookmarksbug
And here is an example document with bookmarks:
c4611_sample_explain.pdf (86.2 KB)
Let me know if you need any more information.
Cheers, Luke.
Thanks Luke,
I will investigate and get back to you soon.
Hi Luke,
This is fixed in 7.3.5 that was just pushed. Sorry about that!
Hi Logan,
I have updated to 7.3.5, however the viewer is still crashing for me when I expand the bookmarks. Here is another PDF to try:
Cheers, Luke.
Please make sure you have swapped out all assets correctly (including the UI) - I am loading 7.3.5 and it is working just fine for me with both PDFs you sent over.
Hey Luke,
Actually I just reproduced this issue - I beleive this is known and should be fixed soon.
Hey Logan.
Thanks for looking into that.
Luke
Hey Luke,
I found the cause of the bug - the fix is just in code review. I’ll push a new version as soon as its ready.
Thanks Logan - apprecaited it.
Hey! Just fixed 7.3.6 with this fix (sorry for delay, I was on vacation). Also look forward to 8.0 soon!
