Hi everyone,
There was been many posts recently about watermarks appearing on the PDF.js Express Viewer product, even with a license key.
Please make sure to follow these debugging steps before creating a ticket:
- Make sure you are using the npm package
@pdftron/pdfjs-express-viewerand not@pdftron/pdfjs-express - The watermark will always appear on localhost. It only gets removed in production environments
- If you recently switched from
@pdftron/pdfjs-expressto@pdftron/pdfjs-express-viewer, make sure the static assets in/publicget properly copied over. We recommend deleting the old assets and completely replacing them
