Pdf not loading correctly side color in the header image is not loading properly
“@pdftron/pdfjs-express-viewer”: “^8.7.4”,
Image in the pdf header is getting cropped from both the sides i.e left and right and not loading properly, please check the attached screenshots
Expected like the above image
Please check in your demo with the provided pdf it is not loading correctly
No only on this specific document
Thank you for reporting this issue, we will add this into our backlog for the product team to review.
