When I am passing this url of my pdf file which is this https://x9oo-fwyq-gkdq.n7.xano.io/vault/cIQOyqj4/aq1ODkTCEIHvsYY7wZn5nZNjVTo/qCt-vA../sample.pdf my viewer is not able to load that file and giving me the default page not found error from my theme. I tried both the ways of loading pdf file from URL as you can see in below code snippet.
The PDF provided from URL should be loaded fine because the pdf file is publicly accessible.
All documents
// path: ‘/webviewer/lib’,
initialDoc: ‘https://x9oo-fwyq-gkdq.n7.xano.io/vault/cIQOyqj4/aq1ODkTCEIHvsYY7wZn5nZNjVTo/qCt-vA../sample.pdf’,
viewer.current
).then((instance) => {
// instance.UI.loadDocument(
// ‘https://x9oo-fwyq-gkdq.n7.xano.io/vault/cIQOyqj4/aq1ODkTCEIHvsYY7wZn5nZNjVTo/qCt-vA../sample.pdf’,
// { filename: ‘sample.pdf’ }
