UI version | ‘8.4.1’ |
Core version | ‘8.4.0’ |
Build | ‘NC8xMi8yMDIyfDRkZTU3MmExYg==’ |
WebViewer Server | false |
Full API | false |
{Description here}
I have the followed the setup for a viewer but no matter what I do I keep getting asked for a license key. I am using a license key as I will show in the code section.
I have taken the the zip file from the download page:
- Unzipped it
- npm install
- npm serve
- put my license key into the viewing.js file
- It works
- Move all the same code into my project and it doesn’t work because its looking for the license key.
I have also tried to do the install as shown on the manual integration getting started page:
I am expecting the license key to be read and used for my local domain (example.test). I have created a license key for the domain example.test incase it was not recognised as a local setup.
The viewer has not loaded for me as yet.
n/a
**Note that I am using the full correct license key from the PDF.js Express page. I just removed it for the code below
<head>
<script src="/js/PDFJSExpress/lib/webviewer.min.js"></script>
</head>
<body>
<div id="viewer"></div>
<body>
<script>
path: '/js/PDFJSExpress/lib', // path to the PDF.js Express'lib' folder on your server
licenseKey: XXXHRt',
initialDoc: 'https://pdftron.s3.amazonaws.com/downloads/pl/webviewer-demo.pdf',
.then(instance => {
Core.documentViewer.addEventListener('pageNumberUpdated', (pageNumber) => {
</script>
