| UI version | “7.2.0” |
| Core version | “7.2.2” |
| Build | “MS8xMi8yMDIxfDcxODAxYzM3NA==” |
| WebViewer Server | false |
| Full API | false |
Hi
i am using the print function instance.printInBackground but in the browser preview this always has a low quality. I entered the call instance.setPrintQuality(10); both before instance.printInBackground and inside
WebViewer (…)
.then (function (instance) {
instance.setPrintQuality (2);
but without success.
Strangely, if I open the print panel, select the HIGH quality, I make the preview then also in my function it is kept high.
It appears that the printInBackground function takes the quality from the panel
high quality print
every document
instance.printInBackground({
pagesToPrint: arrayPages,
includeComments:false,
includeAnnotations: false,
onProgress: function(pageNumber, img) {},
