Code is simple:
instance.printInBackground({
includeComments: false,
includeAnnotations: true,
pagesToPrint: list,
Error Message:
Uncaught RangeError: offset is out of bounds
at Uint8ClampedArray.set ()
at r$jscomp$0 (PDFJSDocumentType.js:2210)
There are [page number] times error Messgae shown in the console.
The resolution of the pdf file is high.(100% scale result in just a small area of the page).
Other pdf files can’t reproduce this.
Thanks for any messages,
Ken
2
Are you able to share the document with me for testing?
The document includes some private information. So I will try to reproduce with some other documents and share with you.
FYI, no errors show in console only when print quality is 1.
Thanks for replying,
Ken
Hi Logan,
I have attached a file having this issue. Please help find out the solution
Ken
H0d525e77765b425fa09827a3d5d32fc8M.pdf (93.5 KB)
6
Thanks for the document, I can reproduce the issue when setting the print quality to 3.
I will investigate and get back to you when we have a solution. We will have to push a new release to fix this one.
For now, I recommend not setting the print quality so high.
