This does not get printed to the developer console when you load express
Recently we found when printing the PDF the dialog box gets stuck on ‘Processing’ and never ends, we can no longer print. We have not made any changes.
It should print…
All
Only console message is: webviewer-ui.min.js:68 react-i18next:: It seems you are still using the old wait option, you may migrate to the new use Suspense behaviour.
We’re printing from the settings menu icon, print.
Yes everything was working fine before, we have not updated anything.
