Problem retrieving annotations from sqlite3
Latest from npm
i’m use this scripts:
with pdftron with no problems. I have modified the original code so that it creates a database per user and a table per pdf.
When i try to use with pdf.jsExpress i can save the annotations, create the table, create the database per user but i can’t restore the annotations when refresh or view with other web navigator.
there’re a annotationsHandler.js:
const fs = require(‘fs’);
const SQLite3 = require(‘sqlite3’).verbose();
const TABLE = ‘annotations’;
module.exports = (app) => {
// Handle POST request sent to ‘/server/annotationHandler.js’
app.post(’/server/annotationHandler.js’, (req, res) => {
const documentId = req.query.documentId;
const nif = req.query.nif;
var nifDB = ‘/var/www/html/WebViewer/annotations/server/db/’+nif+’.db’;
 // Create a database if it doesn't exist
if (!fs.existsSync(nifDB)) {
  console.log('creem la bbdd '+nifDB);
  fs.writeFileSync(nifDB, '');
const annotationId = JSON.parse(req.body).annotationId;
const xfdfString = JSON.parse(req.body).xfdfString.replace(/\'/g, `''`); // To escape single quote character in SQLite
const db = new SQLite3.Database(nifDB);
db.run(`CREATE TABLE IF NOT EXISTS ${TABLE} (documentId TEXT, annotationId TEXT PRIMARY KEY, xfdfString TEXT)`);
db.serialize(() => {
  const isDeleteCommand = /<delete>(.*)<\/delete>/s.test(xfdfString);
  let query;
  if (isDeleteCommand) {
    // Instead of saving the delete command, we can remove the row from the database
    query = `DELETE FROM ${TABLE} WHERE annotationId = '${annotationId}'`;
    // Save document ID, annotation ID and XFDF string to database
    query = `INSERT OR REPLACE INTO ${TABLE} VALUES ('${documentId}', '${annotationId}', '${xfdfString}')`;
  db.run(query, err => {
    if (err) {
      res.status(500);
      res.status(200);
    res.end();
db.close();
// Handle GET request sent to ‘/server/annotationHandler.js’
app.get(’/server/annotationHandler.js’, (req, res) => {
// Read from the database and send the rows as a response
db.all(SELECT annotationId, xfdfString FROM ${TABLE} WHERE documentId = '${documentId}', (err, rows) => {
if (err) {
res.status(204);
res.header(‘Content-Type’, ‘application/json’);
res.status(200).send(rows);
res.end();
db.close();
The annotationsHandler is called by the index.js that i paste here:
var viewerElement = document.getElementById(‘viewer’);
const queryString = window.location.search;
const urlParams = new URLSearchParams(queryString);
var pdf = urlParams.get(‘pdf’);
var nif = urlParams.get(‘nif’);
var DOCUMENT_ID = urlParams.get(‘pdfId’);
path: ‘lib’,
initialDoc: 'http://estapl02.uab.cat/client/llibres/’+pdf,
documentXFDFRetriever: async () => {
const rows = await loadxfdfStrings(DOCUMENT_ID);
return JSON.parse(rows).map(row => row.xfdfString);
}, viewerElement).then(instance => {
instance.UI.setLanguage(‘es’);
instance.UI.setTheme(‘dark’);
instance.UI.disableElements([‘downloadButton’]);
instance.UI.disableElements([‘printButton’]);
instance.UI.disableElements([‘toolbarGroup-Shapes’]);
instance.UI.disableElements([‘toolbarGroup-Edit’]);
instance.UI.disableElements([‘toolbarGroup-Insert’]);
instance.UI.disableElements([‘toolbarGroup-Forms’]);
instance.UI.disableElements([‘toolbarGroup-FillAndSign’]);
var docViewer = instance.docViewer;
var annotManager = docViewer.getAnnotationManager();
// Save when annotation change event is triggered (adding, modifying or deleting of annotations)
annotManager.addEventListener(‘annotationChanged’, function(annots, action, options) {
// If the event is triggered by importing then it can be ignored
// This will happen when importing the initial annotations from the server or individual changes from other users
if (options.imported) return;
annotManager.exportAnnotCommand().then(function (xfdfStrings) {
  annots.forEach(function(annot) {
    savexfdfString(DOCUMENT_ID, annot.Id, xfdfStrings);
// Make a POST request with document ID, annotation ID and XFDF string
var savexfdfString = function(documentId, annotationId, xfdfString) {
return new Promise(function(resolve) {
fetch(/server/annotationHandler.js?documentId=${documentId}&nif=${nif}, {
method: ‘POST’,
body: JSON.stringify({
annotationId,
xfdfString
}).then(function(res) {
if (res.status === 200) {
resolve();
// Make a GET request to get XFDF string
var loadxfdfStrings = function(documentId) {
method: ‘GET’
res.text().then(function(xfdfStrings) {
resolve(xfdfStrings);
PDF.js Express does not support documentXFDFRetriever at the moment. Instead, just load and import your annotations when the viewer loads like so:
WebViewer({}, ele).then(instance => {
   instance.Core.documentViewer.addEventListener('documentLoaded', async () => {
    const JSON = await loadxfdfStrings()
    JSON.parse(rows).forEach(row => {
        instance.Core.annotationManager.importAnnotationCommand(row.xfdfString);
Thanks Logan, that’s works now but with a little problem.
The first time that you tri to make a coment or a line (underline) the console show this error
PayloadTooLargeError: request entity too large
at readStream (/var/www/html/WebViewer/annotations/node_modules/raw-body/index.js:156:17)
at getRawBody (/var/www/html/WebViewer/annotations/node_modules/raw-body/index.js:109:12)
at read (/var/www/html/WebViewer/annotations/node_modules/body-parser/lib/read.js:79:3)
at textParser (/var/www/html/WebViewer/annotations/node_modules/body-parser/lib/types/text.js:86:5)
at Layer.handle [as handle_request] (/var/www/html/WebViewer/annotations/node_modules/express/lib/router/layer.js:95:5)
at trim_prefix (/var/www/html/WebViewer/annotations/node_modules/express/lib/router/index.js:328:13)
at /var/www/html/WebViewer/annotations/node_modules/express/lib/router/index.js:289:7
at Function.process_params (/var/www/html/WebViewer/annotations/node_modules/express/lib/router/index.js:348:12)
at next (/var/www/html/WebViewer/annotations/node_modules/express/lib/router/index.js:280:10)
at expressInit (/var/www/html/WebViewer/annotations/node_modules/express/lib/middleware/init.js:40:5)
and don’t save nothing, the second time the comment is saved, if you wait a minut or change the tool for the annotations make the same, the first time this error and the second time save the annotation.
Any ideas??
This appears to be an issue on your server and not related to PDF.js Express. you probably need to increase the max body size your server allows.
