I evaluate pdf js express plus, (without license key) but I notice that viewer has a different behaviour that your demo page. Such as the documents are rendering slowly. I notice also pdfjs express watermark on document locally.
Did can be because I evaluate without license key?
Hi @user45,
The watermark on localhost will persist regardless of a valid license key. A valid key in production will remove the watermark.
As for the documents there should be no difference. Could you provide one of the documents you are noticing slowness on?
Zach Serviss
