Search a keyword and annotate it programmatically
I have gone through the documentation and setup pdf.js with Vue. For searching a keyword and annotating it programmatically, I have referred the Advanced Search APIs and the sample given(here /documentation/search/advanced-search). The code is the same as the one given in the example. I am getting error when I call the function textSearchInit. Screenshot for reference: https://nimb.ws/A8ZVkR
Please guide me if something is missing or what went wrong here.
The keywords mentioned in the code must be searched and annotated as provided.
I have tried with the default document
        path: this.path,
        initialDoc: this.url,
        enableAnnotations: true
      this.$refs.viewer).then((instance) => {
    const { docViewer, CoreControls, annotManager } = instance;
    const searchMode = docViewer.SearchMode.e_page_stop;
    const searchOptions = {
      fullSearch: true,
      onResult: (result) => {
        const textQuad = result.quads[0].getPoints();
        const annot = new Annotations.TextHighlightAnnotation();
        annot.X = textQuad.x1;
        annot.Width = textQuad.x2 - textQuad.x1;
        annot.Y = textQuad.y3;
        annot.Height = textQuad.y1 - textQuad.y3;
        annot.FillColor = new Annotations.Color(0, 0, 255, 0.5);
        annot.StrokeColor = new Annotations.Color(0, 0, 255, 0.5);
        annot.Quads = [textQuad];
        annotManager.addAnnotation(annot);
        annotManager.drawAnnotationsFromList([annot])
    // start the search
    docViewer.textSearchInit('the', searchMode, searchOptions);
it looks like the code snippet on that guide is missing a few steps (my mistake).
This code should work for you:
  const { docViewer, CoreControls, annotManager, Annotations } = instance;
    // Set search modes. See the API reference for more information
    const searchMode = CoreControls.Search.Mode.PAGE_STOP | CoreControls.Search.Mode.HIGHLIGHT;;
      fullSearch: true // search the full document,
        if (result.resultCode === CoreControls.Search.ResultCode.FOUND) {
          if (!result.quads.length) return;
          console.log(result);
          annot.PageNumber = result.pageNum;
    // start the search
    docViewer.textSearchInit('pdf', searchMode, searchOptions);
I’ll update that guide as well.
Hi Logan,
When I use CoreControls.Search.Mode.PAGE_STOP instead of docViewer.SearchMode.e_page_stop(as in the code snippet given by me), I get the error as: https://nimb.ws/CmiS3a
Can you please check for this as well?
Thank you,
Madhavi
This was a breaking change in 7.0 that moved it to the CoreControls namespace. docViewer.SearchMode.e_page_stop is correct I believe for version 6.
Hi Logan,
Thank you for the quick response.
I upgraded to the version 7.3.2 and the errors have gone. Now, when I call the function textSearchInit, the onResult callback doesn’t fire even though the search keyword is in the pdf. Below is the code example,
      console.log("doc loaded")
      fullSearch: true,
          alert("result");
    startPage: 2,
    onDocumentEnd: function(){
        alert("onDocumentEnd");
    // start the search
    const test= docViewer.textSearchInit('Edit', searchMode, searchOptions);
Screenshot of output for reference: https://nimb.ws/i2hple
Thank you,
Madhavi
Hi Logan,
Actually the search was not working in that particular pdf due to some reasons. I changed the pdf and tried and the above code worked. Thanks a lot for checking.
Regards,
Madhavi
@Logan I noticed another typo in your version 8xx documentation.
const {
    documentViewer,
    Core,
    annotationManager,
    Annotations
  } = instance.Core;
Instead of Core, it should be Search:
const {
    documentViewer,
    Search,
    annotationManager,
    Annotations
  } = instance.Core;
Also there’s duplicate closing semi colons:
const searchMode = Core.Search.Mode.PAGE_STOP | Core.Search.Mode.HIGHLIGHT;;
