PDF.js Express Plus on an Angular 13 app
Original lib version was 7.3.0
Also tested with 7.3.9 and 8.7.0
The mergeDocument() function does not work. The function is being called, but does nothing. The document stay unchanged and only contain the original file.
No error or warning printed in console.
We build the 1st document, then merge others in it, and then call the loadDocument() of the instance. The viewer should display all of the doc.
Every document
Zach Serviss
Sorry for the miscommunication, PDF.js Express does not support document manipulation so mergeDocument will not work in express.
Please use PDFTron for document manipulation.
Zach Serviss
