Some disabledElements seems won’t work on WebViewer annotations sample - using files and PHP backend:
WebViewer({ path: 'lib', initialDoc: 'https://pdftron.s3.amazonaws.com/downloads/pl/demo.pdf', disabledElements: [ 'freeHandToolButton', 'freeHandToolButton2', 'freeHandToolButton3', 'freeHandToolButton4', 'highlightToolButton', 'highlightToolButton2', 'highlightToolButton3', 'highlightToolButton4', 'underlineToolButton', 'squigglyToolButton', 'strikeoutToolButton', 'rectangleToolButton', 'ellipseToolButton', 'lineToolButton', 'arrowToolButton', 'polylineToolButton', 'polygonToolButton', 'cloudToolButton' ] }, viewerElement).then(instance => { var annotManager = instance.docViewer.getAnnotationManager(); // Add a save button on header instance.setHeaderItems(function(header) { header.push({ type: 'actionButton', img: '<svg xmlns="http://www.w3.org/2000/svg" width="24" height="24" viewBox="0 0 24 24"><path d="M0 0h24v24H0z" fill="none"/><path d="M17 3H5c-1.11 0-2 .9-2 2v14c0 1.1.89 2 2 2h14c1.1 0 2-.9 2-2V7l-4-4zm-5 16c-1.66 0-3-1.34-3-3s1.34-3 3-3 3 1.34 3 3-1.34 3-3 3zm3-10H5V5h10v4z"/></svg>', onClick: function() { // Save annotations when button is clicked // widgets and links will remain in the document without changing so it isn't necessary to export them annotManager.exportAnnotations({ links: false, widgets: false }).then(function (xfdfString) { saveXfdfString(DOCUMENT_ID, xfdfString).then(function() { alert('Annotations saved successfully.'); }).catch(function () { alert('Annotations not saved successfully.'); }); }); } }); }); // Load annotations when document is loaded instance.docViewer.on('documentLoaded', function() { loadXfdfString(DOCUMENT_ID).then(function(xfdfString) { annotManager.importAnnotations(xfdfString).then(function(annotations) { annotManager.drawAnnotationsFromList(annotations); }); }); }); });
