and sorry fot this communication.
Your plugin in wonderful, but there’s an error in localization: in the settings, I’ve changed the language in the box from “View Fullscreen” to > “Vedi a Tutto Schermo” (Italian), but, even if updated, nothing happens when I open the page with the viewer.
It remains as “View Fullscreen” in english, in the top-left side…
Please, would you be so kind to take a look?
And, I did not find any .po file in the language directory for changing it.
the problem is in the settings.
There’s a box in which you can substitute “View Fullscreen” text with a text that you want. If you try to write the text in the box, after saving, the View Fullsceen text that appears in the plugin on the page in which you inserted the shortcode, has not substituted with the text that you wrote in the settings page.
