Error when changing default language
|UI version|‘8.3.2’|
|Core version|‘8.3.0’|
|Build|‘My8xNi8yMDIyfDJiMGM2Y2IyZA==’|
|WebViewer Server|false|
|Full API|false|
Javascript error when trying to setup the FR language : “Uncaught (in promise) TypeError: Cannot set properties of undefined (setting ‘i18n’)”
Screenshot : 2022-03-25_10-52-25
just use the right language
all documents concerned
WebViewer({path: ‘assets/plugins/pdf_js_viewer/lib’,
licenseKey: ‘XXXXX’,
initialDoc: fichier,
}, document.getElementById(‘pdf_viewer’))
.then(instance => {
instance.UI.setLanguage(‘fr’);
		instance.Core.documentViewer.zoomTo(2, 0, 300);
thanks for your help
Hi There,
Thanks for your question.
I used your code here and it worked when I changed the quotation marks in the French language, as follows.
.then(instance => {
   UI.setLanguage('fr');
Please let me know if this works for you as well.
Thank you,
Dandara
It works ! thanks
Not sure to understand with this syntax, but it helps !
