We have different view between Chrome and Edge. Looks like in Edge our configuration is not used at all, although the license key and everything loads.
Same view between Chrome and Edge
all
path: “${contextPath}/lib”, // path to the PDF.js Express’lib’ folder on your server
licenseKey: ‘XXXXXXXXXXX’,
initialDoc: “${flexpaperModel.url}”,
disabledElements: [
‘viewControlsButton’,
‘selectToolButton’,
‘fitButton’,
‘freeHandToolGroupButton’,
‘textToolGroupButton’,
‘shapeToolGroupButton’,
‘eraserToolButton’,
‘signatureToolGroupButton’,
‘freeTextToolButton’,
‘stickyToolButton’,
‘miscToolGroupButton’,
‘toolsButton’,
‘searchButton’,
‘menuButton’,
‘searchPanel’,
‘viewControlsOverlay’,
‘menuOverlay’,
‘pageNavOverlay’,
‘toolsOverlay’,
‘searchOverlay’,
‘annotationPopup’,
‘annotationStylePopup’,
‘toolStylePopup’,
‘stylePopup’,
‘textPopup’,
'annotationNoteConnectorLine',
'signatureModal',
'printModal',
'loadingModal',
'errorModal',
'passwordModal',
'stickyToolButton',
'highlightToolButton',
'freeHandToolButton',
'freeTextToolButton',
// initialDoc: '/path/to/my/file.pdf', // You can also use documents on your server
.then(instance => {
//console.log("instance.UI.Feature:", instance.UI.Feature);
console.log("instance.Feature:", instance.Feature);
console.log("instance.Feature.Copy:", instance.Feature.Copy);
console.log("instance:", instance);
const docViewer = instance.Core.documentViewer;
docViewer.addEventListener('documentLoaded', () => {
instance.UI.openElements([ 'panToolButton', 'leftPanel' ]);
instance.UI.disableFeatures([instance.UI.Feature.TextSelection, instance.UI.Feature.Copy, instance.UI.Feature.Search, instance.UI.Feature.Print]);
instance.disableFeatures([instance.Feature.TextSelection, instance.Feature.Copy, instance.Feature.Search, instance.Feature.Print]);
