We are displaying a PDF but we have character/font issue on Chrom/Edge but not Firefox.
Version used :
"@pdftron/pdfjs-express-viewer": "^8.3.0",
"react": "^17.0.2",
See screenshots:
Chrome
Firefox
Do you have any clue on that?
Version used :
"react": "^17.0.2",
See screenshots:
Chrome
Firefox
Hello jkeruzec,
PDFTron
Hi Tyler,
Thank you for your support,
I’ve tried:
File is working well with built-in PDF viewer in Chrome
I’ve made a subset of the non working pdf
YINTR22242_Computing_and_AI_for_Automotive_2022_Report.pdf (322.8 KB)
Julien.
I’ve simplified my code at the extreme.
Windows 11 but also doesn’t work also in windows 10
Edge version : Microsoft Edge
Version 102.0.1245.39 (Version officielle) (64 bits)
Very simple interface, no css at all except yours
Same code Firefox 101.0.1
Viewer code
import React, { useRef, useEffect, useState } from 'react';
import WebViewer from '@pdftron/pdfjs-express-viewer';
import Box from '@mui/material/Box';
import Grid from '@mui/material/Grid';
import ListDocumentsByType from '../../components/ui/ListDocumentsByType';
import documentService from '../../services/catalog/DocumentServices';
const Viewer2Page = (props) => {
const [documents, setDocuments] = useState([]);
const viewer = useRef(null);
const isProductId = Number.isInteger(props.productId);
useEffect(() => {
documentService.getDocumentsByProductId(props.productId, props.jwt).then(json => {
setDocuments(json);
const config = window.env[window.env.mode];
const currentPdf = config.apiMainEndPoint + "/catalog/documents/file/filename/" + json.find(data =>
data.documentTypeId === 2).filename + "?token=" + props.jwt;
initialDoc: currentPdf,
licenseKey: props.licenceKey
viewer.current,
).then((instance) => {
instance.UI.openElements(['thumbnailsPanel']);
}, [props]);
return (
{isProductId
<div className="webviewer" ref={viewer}></div>
: <p>No product found</p>
export default Viewer2Page;
Hello jkeruzec,
We have found a Microsoft forum post explaining a very similar issue: Redirecting
The text chopping looks almost identical to the ones reported here.
We are looking into any workarounds, but to clarify Windows 11 but also doesn’t work also in windows 10 does this mean it happens both in Windows 10 and 11? Or just Windows 11.
PDFTron
We have the same issue with Windows 10 as well …
Tested on Opera, same trouble.
Only Firefox is the best on this, no issue with it !
Hello jkeruzec,
Thank you for posting on that MS forum page, it makes sense that Opera is also producing the same result since it is also Chromium based.
I found a potential workaround here: PDF rendering issues in Google Chrome on Windows 10 : Papers Support
Let me know if this works for you!
PDFTron
Yep workaround is working for me,
I’ve updated to the latest windows, latest chrome, latest graphic driver but still not working…
I hope this will be fixed by graphic card driver/chromium engine soon !!
Thanks for the support !
