Warning: Setting up fake worker. … cannot read properties of undefined (reading ‘workermessagehandler’)
I am trying to develop a viewer using ur PDFJSExpress package on a React/NextJS app, and everything is ok except that from time to time I am getting a popup message on the viewer saying that “Warning: Setting up fake worker. … cannot read properties of undefined (reading ‘workermessagehandler’)”
I have searched Hi and low for this … would appreciate any help on the matter please
Thanks in advance
Random documents, sometime will work some times will show popup
`const WebViewer = (await import(‘@pdftron/pdfjs-express-viewer’)).default;
path: '/pdfjs/lib',
licenseKey: 'NIV4p9fOcUkApaoyG7kA', //TODO: Move to env
// initialDoc: '/downloads/MARC-Data-Consent-Notification-v2-is215-a.pdf',
}, viewer.current).then((inst: any) => {
instance.current = inst;
if(type === 'FILE') {
inst.UI.loadDocument(data, { filename: 'MARC-Data-Consent-Notification-v2-is215-a.pdf' });
if(type === 'BASE64') {
inst.UI.loadDocument(base64ToBlob(data), { filename: 'myfile.pdf' });
// you can disable annotations
inst.UI.disableFeatures([inst.UI.Feature.Annotations]);
// customize the UI
// inst.UI.setTheme({ primary: 'blue', secondary: 'white' });
const { Core } = inst;
console.log('PDF documentViewer loaded');
onLoad(data);
Core.documentViewer.addEventListener('loaderror', () => {
console.log('PDF documentViewer error');
Core.documentViewer.addEventListener('pageNumberUpdated', (pageNumber: number) => {
