What is the color code for no fill?
We’re using a custom header and want to put the option for no fill but don’t know the color code.
this.wvInstance.setColorPalette({
toolNames: [ToolNames[‘TEXT’], ToolNames[‘FREETEXT’], ToolNames[‘LINE’], ToolNames[‘RECTANGLE’], ToolNames[‘FREEHAND’], ToolNames[‘HIGHLIGHT’]],
colors: [
‘#ffffff’,
‘#FF0000’,
‘#0000FF’,
defaults: [{StrokeColor:‘#FF0000’}]
Hello shiran305,
For the no fill color palette option, you can simply set the opacity to be 0:
    instance.setColorPalette({
      toolNames: [ToolNames['TEXT'], ToolNames['FREETEXT'], ToolNames['LINE'], ToolNames['RECTANGLE'], ToolNames['FREEHAND'], ToolNames['HIGHLIGHT']],
      colors: [
      '#ffffff',
      '#FF0000',
      '#0000FF',
      defaults: [{
        StrokeColor:'#FF0000',
        FillColor: new instance.Core.Annotations.Color(0, 0, 255, 0),
Reference document can be found here:
I should have been more clear. We are using the draw a shape tool, the demo has a no fill option. Putting it to 0% opacity doesn’t make a box.
Hello shiran305,
The color code for no-fill is ‘transparency’:
      colors: [
      '#ffffff',
      '#FF0000',
      '#0000FF',
      'transparency',
