I am putting together a small proof of concept to test out the PDF.js Express Viewer library. I’ve been able to load up a PDF from the React/Vite project’s public directory just fine, and I have found topics where people have loaded PDFs from public URLs and pre-signed AWS S3 URLs.
Is it possible to asynchronously load PDFs through a stream? All PDFs are stored on a NAS server. I’d like to make an API request to our server that would then serve back the file stream.
The alternative solution in my mind would be to create public access to the NAS server. Though it’d be through a reverse proxy, it’s still not ideal, for obvious security reasons. It’d also mean having to configure and maintain an external solution outside of the main project’s codebase.
Can you share a sample code how you are loading the PDF through a stream?
Here’s our documentation regarding loading PDF through different domain:
Here is a forum guide that may help you answer some of your questions:
I haven’t tried a solution yet, as my question is how to go about doing that. I’d like to be able to load the PDFs through a Node.js Express backend and serve the file back up to the React frontend. I’m trying to avoid having to statically host the files with a public URL.
Like you mentioned, the alternative would be to create the NAS public.
If the NAS server is a subdomain, then you could potentially make a request but there are some things to be mindful of, like CORS issue within an iframe:
It looks like there’s a lot simpler way I can do this using express.static. The server will have access to the NAS server, I can just create a static path and hide the URL behind a private route. Then for additional security I can generated uuid’s in the database mapped to each PDF so the frontend just passes that into to my API and it can find the correct file.
Example of using express.static, for anyone else that may have this concern. Add the following to the server index:
