Can we use textSearchInit(pattern, mode [, searchOptions]) for a regex as pattern?
Currently textSearchInit() function is working fine for a single string but not for a regex.
Need to apply this function for a regex.
  const { CoreControls } = instance;
    let arr = [" ICO ", " 30/45 ", " 6AR ", " LD ", " 70D ", " 120 ", " EZ10 ", " TRW ", " CRI90 "]
    const regexFromMyArray = arr.join("|");
    const mode = CoreControls.Search.Mode.PAGE_STOP | CoreControls.Search.Mode.HIGHLIGHT;
    const searchOptions = {
      fullSearch: true, // search full document
      onResult: result => {
        if (result.resultCode === CoreControls.Search.ResultCode.FOUND) {
          const textQuad = result.quads[0].getPoints();
          const annot = new Annotations.TextHighlightAnnotation();
          annot.X = textQuad.x1;
          annot.Width = textQuad.x2 - textQuad.x1;
          annot.Y = textQuad.y3;
          annot.Height = textQuad.y1 - textQuad.y3;
          annot.FillColor = new Annotations.Color(0, 255, 0, 0.5);
          annot.StrokeColor = new Annotations.Color(255, 0, 0, 0.7);
          annot.Quads = [textQuad];
          // add custom property so we can check in annotationSelected function
          annot.IsCustomSearch = true;
          annotManager.addAnnotation(annot);
          annotManager.drawAnnotationsFromList([annot])
    // start the search
    docViewer.textSearchInit(regexFromMyArray, mode, searchOptions);
  // Listen for when our search annots are selected
  annotManager.on('annotationSelected', (annots) => {
    if (!annots) return;
    annots.forEach(annot => {
      // check that our custom 'IsCustomSearch' property is set
      if (annot instanceof Annotations.TextHighlightAnnotation && annot.IsCustomSearch) {
        const { X, Y, Width, Height } = annot;
        // Here you can use X, Y, Width, Height
        // to create a new Rectangle Annotation!
Sorry for the late reply here, somehow this message slipped through the cracks.
You can add CoreControls.Search.Mode.REGEX to your search mode, like so:
const mode = CoreControls.Search.Mode.PAGE_STOP | CoreControls.Search.Mode.HIGHLIGHT | CoreControls.Search.Mode.REGEX;
Hey Logan ,
Thanks a lot! This really solved the problem I was having.
