Searching list of words not working on pdf viewer
Error - Unhandled Promise rejection: TypeError: e.split is not a function
Should highlight all the words matching in the pdf.
let arr = [‘RAS’, ‘Cable’, ‘92780’]
var regexFromMyArray = new RegExp(arr.join("|"), ‘g’);
console.log(‘regex…’, regexFromMyArray)
instance.docViewer.setSearchHighlightColors({
searchResult: ‘rgba(0, 255, 0, 0.5)’,
activeSearchResult: ‘rgba(0, 255, 0, 0.5)’
instance.searchText(regexFromMyArray)
Sorry, I should have been a bit more specific in my last comment.
You’ll probably want to do something like this:
var regexFromMyArray = arr.join("|");
instance.searchTextFull(regexFromMyArray, { regex: true })
The things I changed here was using searchTextFull instead of just searchText, and using a string representation of the regex rather than an actual regex.
I hope this helps!
