abe
1
- I followed this tutorial: PDF.js Express Viewer Download & Integration | Documentation
- I want to disable the print function including (CTRL + P)
Yes
How can I disable that?
system
2
Guides:
APIs:
Forums:
3
Hey there! You can disable print with the disableFeature api:
instance.UI.disableFeatures([instance.UI.Feature.Print]);
