Custom trigger to hyperlinks / link and goto that are already created in original PDF
Hi, I am trying to display PDF documents that have external hyperlinks to files. First I need how to Active those links to work.
Second, I need somehow to catch the event when the user click the external hyperlink and try to redirect it to existing file in the server.
I try this link for PDFTRON but it don’t work.
https://groups.google.com/g/pdfnet-webviewer/c/H0353b6vYwU
First, When the user click on the hyperlink, open a blank page with the link
Hey there! Thanks for trying out PDF.js Express.
You’re super close. For external links, you’ll actually want to override the URI Action instead of GoToR.
WebViewer(...).then(instance => {
  const uriTrigger = Actions.URI.prototype.onTriggered;
  Actions.URI.prototype.onTriggered = function(link) {
    //uriTrigger.apply(this, arguments); // uncomment this to use default functionality
    console.log(this.uri);
With the URI you can do whatever you wish.
Let me know if theres anything else I can help with.
Hi Logan, thank you for your answer.
I managed to do trigger my custom event with the PdfTron demo. How ever , I didn´t have success with the PDF.js Express demo.
In Pdf.js Express the annotations are not returning actions.
This is my code
path: ‘PDFJSExpress/lib’, // path to the PDF.js Express’lib’ folder on your server
licenseKey: ‘Insert commercial license key here after purchase’,
initialDoc: ‘WebViewer/samples/viewing/viewing/ejemplo3/test.pdf’,
        .then(instance => {
         //PDFTron return actions but PDF.JSExpress don't
         docViewer.on('annotationsLoaded', () => {
                const annotations = annotManager.getAnnotationsList();
                annotations.forEach(annot => {
                    var a = annot.getActions();
                    if (a.U) {
                        if (a.U.length>0) {
                            var act = a.U[0];
                            if (act.elementName == 'URI') {
                                var auri = act.fr;
                                act.onTriggered = function (dispacher, event, owner) {
                                    //Do something
Please note that you cannot rely on the minified properties such as a.U and act.fr, as these may change between versions/builds.
Is the issue that annot.getActions(); returns an empty array using Express?
Thank you Logan, I will fix the code to not use the minifield properties.
Yes , in Express annot.getActions() returns an empty array
Would you mind sharing the document you are having issues with?
of course!
test.pdf (33.6 KB)
Thanks @fbenavides !
I can reproduce your issue and will look for a fix today.
Hey again,
I found a fix and it will be fixed in the next patch, which I’ll push out either today or tomorrow. I’ll announce it in #announcements so keep an eye out!
Thank you for your patience with this one.
Hey!
This was fixed in 7.3.1
