Internal links don't work in PDF.js Express viewer
When I click a hyperlink in the document which should take me to another page or position inside that document, as it does on Preview, the Google Chrome PDF viewer and when using the react-pdf library, nothing happens.
Internal links take you to another page or position in the PDF document.
Every document.
Our setup uses the following code, but I’ve also tested this functionality using the PDF viewer demo and internal links aren’t working on there either.
          path: '/pdfjsexpress',
          licenseKey: "LICENSE_KEY_GOES_HERE",
          initialDoc: pdfUrl,
          enableAnnotations: false,
          disabledElements,
          disableLogs: true,
          isReadOnly: true,
          css: '/pdfjsexpress/ui/dark-theme.css',
Hey!
This is expected behaviour as PDF.js Express Viewer does not have annotation support, and links in PDFs are technically annotations.
If you need support for this you would have to upgrade to PDF.js Express Plus, which does have annotation support.
Hi Logan,
Thanks for getting back to me so quickly. That’s a shame as I’d assumed internal links would be treated slightly differently to other annotations, but I guess we’ll just have to work without that feature!
Best,
James
