Hi team ,
I want to now how can I add drop down list in comment.
Technology : Angular
Guides:- Hiding annotations in WebViewer notes panel - setCustomNoteFilter
- How to customize viewer - What option should I choose
- Add signature fields to PDFs - createSignHereElement
To do more advanced customizations like this I recommend you fork our open source UI and make your changes directly to our source code. There is a guide on doing so here.
If you don’t want to take that approach, we do have an experimental API that allows you to transform the content of each note rendered in the notes panel. This may be able to do what you want.
